hey chris, i have considered carry one too but, i'm already so tight on room that i wouldn't know where to store it. I carry a 12 ton bottle jack instead in the rear cubby along with some pieces of 2x4 and, they have always served me well on the trail.
Eddie space is my main concern as well.
Thanks
I got rid of my scissor jack awhile ago and just use this now. The 12 ton bottle jack goes pretty tall and the blocks of wood give me more options.
I would do this, but I think I would miss the way my Jeep sways back and forth when lifted with the scissors...seriously, this is a good suggestion. I'm getting a bottle jack.
Man, Eddie will let anyone into this forum :bleh: What is going on my Calgary Brother? How are those 40"s working out for you Chris? Good to have you here on the forum my friend.
LOL at the swaying scissor jack. not so bad when stock but totally useless when trying to lift a 2,000 lb heavier vehicle even on stable ground.
i carry 4 pieces of cut down 2x4 blocks with my bottle jack and this allows me to make a wider base if on soft sand, stack them if needed to go taller and even position one vertically you need to get to a higher spot. it's really quite versatile and so much so that i can't even recall the last time i've used a hi-lift on the trail.
This is why I wheel with you. I don't have to be prepared. You are :bleh:
