TRLJNKY
Ok. Need some further guidance please. A few weeks ago, I bent the hell out of my tie rod, stabilizer, and found my lower ball joints were smoked.
I replaced the ball joints, straightened the factory tie rod, and replaced the stabilizer with oem equivalent.
While doing the ball joints I torqued everything to spec to include the track bar.
Im also running spacers and a D30 with only a budget boost so factory springs and control arms.
Since replacing the ball joints, stabilizer, and fixing the tie rod I still notice that the front end seems flighty. Bump steer and and hwy speed shimmy is noticeable. When I turm the wheel I notice a clunking sound occasionally (Im sure I heard that before the incident). I cant find anything else noticeably wrong. Unit bearings seem fine.
I tossed it on my alignment machine at work and noticed my camber was at 1° on my left front (mild bent c possible). I dialed in my toe but also noticed my castor was off. It was in the 3° range and highlighted red. Im not an alignment tech so I may just take it in and get it rechecked with someone that does it all the time to be sure. But if my castor is off it could cause my bump steer or flighty issue correct? I have a mildly bent r/r lower ca but fronts look fine so not sure how Id knock my castor out.
BLUF, what else should I check? Im a mechanic by trade so its kinda frustrating me Im missing something possibly that is glaringly apparent.
Im on a budget so is it possible to start replacing with say EVO jj CA's without buying a whole kit to start the process? I know its prob more expensive in the long run but wifey would never let me plop 2k or more down on a lift in my foreseeable future and I still want to play with what I have. Run whatcha brung mentality. Thanks everyone.
