flashcal
dentdude36
my flashcal came today and i have a question on measuring tire heigth, i read that the proper way is to measure fro the ground just to top edg of tread rather than from ground to top of tire, any input greatly apreciated
Measured mine from the ground to a level point off the edge of the tire.
Sent from the"Zone of Influence"
I measured to the top of the tread as that is going to be the most accurate reading. However with time the tread wears and your speedometer will be slightly off especially if you have deep tread mud terrain style tires, then you may want to re measure. I used a speedometer app on my phone but you can use a GPS to track your speed when using cruise control to dial it in. I'm only a couple MPH off at 70MPH
Measure from the ground to where the bottom of the tread meets the tire.
Sent from my iPhone
thanks for the advice it worked perfectly, speedo is dead on and the one touch signals and daytime running lights are awesome, now i just need to download the program to turn off the tpms.
