Gibbo
In preparation to fitting new JE Real drive shafts, I'm replacing the cam bolt set up that came with this lift, with some synergy cam bolt elimination washers. I'll put a couple of small welds on each one so they will never move.Then I have some Currie adjustable front lower, and rear upper control arms to replace the stock ones with. My question to you all that have done this before is, what's up with the rear control arms upper bolt that goes through the frame on each side. Does the nut stay fixed in position on the inside of the frame as the fuel tank is in the way on one side. My next question is if I do one side at a time, will the remaining arm hold everything in place while I adjust the new one to fit the open bolt holes. I'm going to do this in 2 days time.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
