Glad to hear you got it together. Your Jeep looks great! How is the ride?love it.......i used the medium duty bought from baddestcross
Im really thinking about trying to fit 37s under mine on the evo level kit instead of the full on 3" enforcer.i was thinking the samething about the 37's
They should fit with no problem as long as you have enough bump stop.Im really thinking about trying to fit 37s under mine on the evo level kit instead of the full on 3" enforcer.
That looks great!!!
What did you net in the front with the 2" plush rides?
I'm guessing 3 maybe slightly more?
Yeah I figured I would call evo and piece together what I needed out of the 3" kit, and then just get front springs, break lines, rear track bar bracket, and control arms for caster should cover it though. And some hockey pucks for bump stops.They should fit with no problem as long as you have enough bump stop.
Not sure if the level kit covers it, but you should relocate your brake lines and either raise or drop your rear track bar to keep the geometry in line with the taller rear springs as well as adding 2" rear bump extensions.
Ok cool so showing 3.25" of lift with the stock front bumper not bad at all should net anywhere from 2.75-3" on one with a bumper and winch, thanks for the info!measurement at shock in 21 3/4 inches
to the bottom of the fender is 41 inches,,doesnt mean much but in looking at a little over 3
If your not getting bump steer I wouldn't mess with a track bar bracket. When I was at 2.5" I had one and it caused bump steer. You need to keep the track bar and drag link parallel so if you do install one you might need to do a drag link flip also.Do you really think I need a track bar bracket for that set up
We were referring to the rear track bar bracket, which at 2.5-3" may or may not be needed.Do you really think I need a track bar bracket for that set up
As stated above i was referring to the rear track bar bracket not the front. And agree with you I wouldn't raise the front track bar unless I was running a drag link flip, which at 3" I'm not sure I would need.If your not getting bump steer I wouldn't mess with a track bar bracket. When I was at 2.5" I had one and it caused bump steer. You need to keep the track bar and drag link parallel so if you do install one you might need to do a drag link flip also.
Just wondering about the rear at this point no issues yet just trying to make sure everything is right
