Fenders for JKU
Welcome to WAL! I live in Omaha too :thumb:
I think Smittybilt makes a set of steel fenders that are pretty thin and narrow, but on a JK if you hit a tree hard enough with metal flares, you will bend the sheetmetal on your body. Most people elect to cut their stock plastic flares.
That is certainly an option and seems to be a trend on this forum but that is not what he is asking about. There are a number of companies out their offering aluminum or steel fenders which many people prefer.
Steel fenders on JKs seem to be popular on mall crawlers as they do look nice, but as others have said they are not as functional on rigs that actually go wheeling. A significant hit will cause damage to the body.
I think a good compromise is MCE flat fenders. Flexible and durable plastic, but look cleaner than cut stock flares. Just my opinion, I'd still cut stock flares though as it is waaay cheaper. Here is a photo of MCE flares for reference.
This just happened to someone recently after hitting an object with a steel fender.
Been there.... absolutely TRASHED the sheet metal fenders and destroyed my aluminum poison Spyder fenders plus apron damage after laying it on a boulder. Plastic for me from now on... I've been running MCE for the past year and I'm really happy.
Okay, smartass, then my answer to his question would be, "None of them."
The picture above isn't the first time something like that has happened. I posted it to potentially save the OP money and damage on the Jeep. It is indeed another option.
Woah woah woah.....
There's good reason that metal flares aren't a trend on here. Because they suck! As stated, if you hit something.. you're going to do severe body damage. Of course we are going to try and point the OP to something better, and safer.
I used to run plastic bushwackers until rubbing a boulder dimpled my rear quarter panel... The fenders didn't flex, the body did. I also watched as my buddy hooked a boulder with his MCE front fender... The fender folded beautifully, and the screws they used to attach started tearing out of the soda can thick sheet metal, but only after folding the body panel as well. Later that day he leaned his rear fender against a tree... the fender folded and allowed the tree to contact and dent his body just below the bed rail. I leaned against the same tree, but my MC Overlines (purchased after the bushwacker incident) kept my body off the tree and I pulled away without damage. If I had it to do all over again, I would just cut the stock fenders and roll with it. They flex, and more importantly the clips allow them to pop off before damage is done.
I do like my MC Overlines. I have rubbed and hooked them on numerous occasions and so far they have performed as advertised. If looking for metal fenders and you wheel I would suggest you look for those which attached to the sub-frame in the front and use some type of body armor on the rear (there is no sub-frame to attach to back there). I also seem to rub my rear fenders far more than the fronts. MC has recently released a narrow option for the JK, and Crawler Concepts also has a set with rear armor (not sure of others). In my experience, if going with plastic, I would not spend money on anything but a sawzaw, sandpaper and door edge protector.
Disclaimer: The opinions expressed above are those of RockyMtnAnvil and do not represent those of WAYALIFE or its affiliates. This unpaid advertising is brought to you by "my personal experience". It goes without saying that off-roading with or without fenders regardless of material or manufacturer can be dangerous and expensive and should not be attempted by those interested in saving money for retirement.
Lol! Love the Disclaimer!
OP specifically said steel and narrow all you had to do was read the question. Rather be a smartass than a dumbass! :beer: ;)
If someone asked you what the best way to put your dick in a blender was..... Would you respond with 'high speed' or 'dont put your dick in a blender?' :idontknow:
Depends on if it's a Vitamax or Ninja. I'd be scared of the Ninja cause in the commercial they throw a cell phone into it and grind it up.
Negative, OP asked for the "best" steel and narrow flares. If it's "best" not to do them because the will cause more damage than they prevent, recommending to avoid them is perfectly valid.
Thanks for playing
I love the Disclaimer... Priceless!!
