ssh6314
33's and stock. Full flex. Ugh. Can't wait for the enforcer and 37's.
Sent from my EVO-3d using WAYALIFE app.
Sway bar add support to the suspension by preventing excessive uneven travel of the axle by putting a twisting bind on the sway bar when connected once disconnected the axle will travel freely up and down and allows the suspension to fully droop or compress unevenly unlike with the sway bar will try to keep the axle to cram as parallel as possible
I wanted to. But I don't have quick discos. And this was 30 min before work :s was fun though. Those 33s with all that back spacing barely tucked under the rear
Ah Yes! The glorious 37"s on a 30 discussion... that is always a good time!
andrew -
I plan on EVO gussets and .44 mag sleeves regardless. I'm not sure how else to reinforce the d30. But would love to find out. I know no matter what I do. It's still a Dana 30. But realisticly. My jeep is a daily driver 5 days of the week. And a trail jeep on the weekends. And there isn't much like what Eddie and crew do up Here in Washington. So I think I could run the 37's with care. Opinions welcome.
I run 37" km2s (OK so they r 36.5" but they r lite) on my 30 with 5.13s. Yes I know it is gonna go at so point, but 500$ to sleeve and gusset was/is cheaper than a pr44. I would actually be more willing to find a 44 off a rubi that someone is upgrading out of. I don't wheel that hard and it is my DD. I will eventually have a 44 of some sort, just hope to stretch it out a bit.
so it can be done, you just have to GO SLOW, pick your lines and know your limitations. You must also understand that EVERYTHING breaks.
That being said...... who has a front 44 they are not using?
andrew -
