You can see it in the second pic, down low. If you planned on cutting these, you'd cut off most of it using the typical lines guys choose. It's from hitting something on the road and it kicked up. Not trail abuse.Where is the crack and how bad?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Not sure on fixing. Probably doable if you know what you're doing (and I don't). Also depends on if you plan on cutting them or not. If you cut them, you could eliminate most of the crack.Granite, I might be interested, how much for the set? Can the crack be fixed?
No buyer so I'm cutting these
