Evo Ultra high clearance long arm kit in conjunction with Bolt on coilover
DJCFHB
Evo high clearance long arm kit in conjunction with Bolt on coilovers
My questions is do you use the stock mount on the rear axle or does evo send you a different bracket to replace it other than the rockstar skids. Pictures of the setup would be helpful. Thanks in advance.
The high clearance upgrade kit comes with new weld on rear lower mounts. These must be installed for the high clearance kit to work correctly. Sorry no pics, it's a 3 piece lower mount that needs assembled and welded together on the axle.
So there is a separate bracket welded onto the rear of the axle that the coilovers bolt to?
The brackets raise the Lower control arm mount and relocate the shock mount/coilover mount higher on the axle. However on the bolt on coilovers it's not the same shock mount. Please consult the salesman (jake) before you order.
