MericaMade
Can the Evo sliders be bolted on? I know and understand welding in stronger but at the rate I change my mind I would prefer to bolt on if possible. Has anyone bolted their slider on rather then weld?
I don't think the tabs on their sliders are large enough to put bolts through. Also, they don't have the extra bracketry that would be needed to support being bolted on.Can the Evo sliders be bolted on? I know and understand welding in stronger but at the rate I change my mind I would prefer to bolt on if possible. Has anyone bolted their slider on rather then weld?
Same here. I'm running the PS Brawler Rockers. They are a boat side style compared to EVO'sI don't think the tabs on their sliders are large enough to put bolts through. Also, they don't have the extra bracketry that would be needed to support being bolted on.
Look at LoD, Rock Hard (I think), or Poison Spyder for bolt-on options. I'm personally very happy with the looks and performance of my Poison Spyder bolt-ons.
I went through a lot of back and forth when I chose the Rocker Knockers because I wanted a step for my wife but was afraid of anything body mounted. How have yours been holding up?Same here. I'm running the PS Brawler Rockers. They are a boat side style compared to EVO's
The wholes in the flanges are plenty big for bolts, probably 1/2" or larger. Pre drilling and running bolts through the frame would be an absolute pain in the ass, and would be less sturdy than welding.
Ok that make sense. I tend to change my mind a lot so this is why bolt on would be better for me, but I do understand what you guys are saying. If it has not been done or should not be done then welding them on it is.
Trust me, welded on you will not be disappointed. There are lots of great bolt on options out there if you have commitment issues [emoji482]
After looking at a few of the other installs of bolt on styles it looks like you need to drill and tap quite a few holes. Because I have the recon rock rails now I figured others would bolt on similar.
Hell, if I got to drill 10-12 holes in the frame for bolt on's, I would be better off trying that with the EVO's. But like always, and because you guys have kept me in the right lane since the beginning I will find a friend who can weld or just take to a shop to do so and beat my commitment issues .
I think you only have to drill one hole on each side unless you're gonna do the boatsides. But you can't go wrong with the EVO sliders if that's the route you choose.After looking at a few of the other installs of bolt on styles it looks like you need to drill and tap quite a few holes. Because I have the recon rock rails now I figured others would bolt on similar.
