EVO Rockskin Taillights
I'm preparing to install some rear skins on my rig in the next couple weeks. My question is what lights are you guys running? My original plan is to go with the EVO or PS lights, although I was leaning towards the PS as they already have extra wires in the harneses for reverse and whatnot. For reverse I plan on adding cubes or the new Rigid chase light. I also someone here said that Maxxima also has a stop/turn/reverse light in one, which would simplify things a lot more.
Yes please.
From ORO
"Thank you for your interest in our lights. I have attached a few
documents for you to look at. To stop the fast flash with our method,
you do need your stock turn signal bulbs in circuit. If you have already
cut these out, you can buy the resistor for Poison Spyder for $14.99
each I believe.
It doesn't appear that I have a document for the brackets you will need
to mount the lights with the whole that is already there. Basically the
bracket has 4 tabs on it. 2 for a 4.5inch hole and 2 for a 4inch hole.
Bend the correct tabs for you hole and it will allow your light to stay
in place when you tighten the light to the bracket.
Tailights- $199.00
Brackets- $18.00
LiteBoxes- $29.00
In the LitePanel install doc, ignore everything but the wiring of the
lights."
I am trying to add attachments bear with me.
I'm getting ready to order evo corner skins shortly I'm leaning more towards the aluminum skins. I have the evo tire carrier that requires the skins. Let me hear the pros and cons for the aluminum vrs the steel. Besides the price difference.
