EVO Protek Skid System and LOD Rock Sliders Compatibility
TX_JK
I have the EVO Protek Skid System on my 4dr JK and was contemplating the LOD Rock Sliders. I read WOL's writeup on the LOD Rock Slider installation and it looks like where the sliders mount to the frame would interfere with the same mounting locations that the EVO Protek Skid System uses.
Is anyone running this combination or started down this road only to find the two wouldn't work together and ended up going a different direction?
Planning is so important. Its always not as simple as bolting on MOD #1 without undestanding the ripple effect of how it might compromise the installation of MOD #2.
Thanks,
Michael
Same thing, I run this exact set up and no problems. You can look at my build thread for pics. If I remember after I get off work I'll try to take a few pics and post em up
Am running same set up. Only issue is tight fit in having to slip protek on frame first between frame and protek skid.
I'd had my Lods bolted on at first. After I welded them on I just cut the front lower frame mount tab off.
