Un-bolt the passenger side upper arm and then set your caster. Once you got it adjust the passenger side so you can bolt it back in. There is a right up for adjusting all 8 arms you should check it out.
https://wayalife.com/showthread.php?t=33611Ok. Sounds good.
What is the write up called?
Thanks!
Sorry, can't help you there... Maybe clamp the new setup in place to give you a general idea of where the bumps will be once they're installed?Awesome! Thanks!
How do you decide how far forward to position the axle when you don't have bump stops?
My spring tower and bump stop on the frame have been removed for the DTD towers.
Awesome! Thanks!
Awesome! Thanks!
Awesome! Thanks!
