aTX427
Hey guys, I understand the high clearance mounts are designed for the Evo Lever and mounting the rear lowers to the bolt on Rockstar mounts will effectively provide the same poor geometry as short arms. Having said that, I may upgrade to the Evo Lever kit in the future and do not want to pay twice. I read that ORE will install the high mounts with custom coilover mounts that are not available to the general public. I want ORE to do the installation, but would like to see pictures of the mounts to determine if this is something I want to do sooner rather than later. I would assume ORE uses the standard Evo Lever rear axle mounts for correct geometry and the custom mounts are only for the coilover's - correct?
