Hey all,
I am installing my EVO Enforcer 3" stage 3 suspension kit.
The problem I am having is that on the front lower control arm, the adjustment sleeve is hitting the control arm mount on the axle side before the shocks get to fully extended.
The adjustment sleeve is turned out 2.5 times, which is 1/4" gap between the end of the control arm tube and the hex nut on the adjustment sleeve.
The Johnny joint has 5/8" of threads showing.
The front shocks I have are the Rancho 9000XL RS999331
Extended length of the shocks are 27.32".
The adjustment sleeve hits the control arm mount at around 26.5" of extension.
What would be the correct thing to do?
- Turn in the adjustment sleeve and extend the Johnny joint so it doesn't hit.
- Trim the control arm mount so the adjustment sleeve hex nut doesn't hit.
- Something else?
- Something else?
