I'm getting the enforcer lift here in about 2-4 weeks and am going with 4".
I know I will have to replace the front driveshaft, but does it need to be done immediately? Or just soon after?
It will most likely hit your exhaust crossover when flexed unless you replace it or use a spacer. Of course the spacer only solves part of the problem so a new DS is a better bet.
You will also have to move your evap skid over a couple of inches to keep your rear DS boot from making contact with it and tearing. Ask me how I know. :doh:
Might be a dumb question. When moving the skid are you also moving the actual evap? Or is it as I've seen on a few posts where you remove the skid itself, drill new hole, move over and reinstall.
- Jason
The EVAP is attached to the skid so yes, everything gets moved over.
OK.. One more question.
Can I run the stock wheels and tires with the lift until I can afford new ones?
Cause I plan on getting 5x, 37x12.50x17 Nitto Trail Grapplers, and 5x ATX Slab beadlocks. But it will be a while after the lift.
No, unless you want to leave the rear sway bar links off. I lifted mine and didn't realize that the rear links were actually touching the rim.
I wud do it right away , I have the same kit and I actually tore the DS boot just by removing it from the jeep so I wud def advise changing it out or just run no front DS till ur ready to put in the new one
I don't always wheel , but when I do I keep it tight......... Stay dirty my friends.
You tore the boot by taking the driveshaft out? :thinking:
