The drag link flip is very intimidating. In reality its very simple.
-undo draglink from axle side
-measure length of threads showing under the sleeve with two clamps on it
-remove clamps from sleeve and spin the old longer side of the link out.
-spin the new one in and get it to about your measurement
-drill out the hole on the steering knuckle(make sure to be very generous with cutting fluid when drilling) and drop the sleeve in and connect your new draglink
-cut the old bracket on your axle and bolt on new evo bracket
-move sway bar links to new brackets on both sides
-move track bar to new hole
-spin the clamp on the tie rod on the end of the steering stabilizer(drivers side) so the bolt is pointing up
-disconnect passenger side of steering stabilizer and move to new hole
Tighten everything and spin that sleeve on the draglink itself to recenter steering wheel. When you find your mark spin the clamps so the bolt is lined up with the slit in the sleeve. This keeps it from moving when you hit bumps.
Hope i didn't forget anything and i hope these pictures help!
Before moving steering stabilizer
After
