TonyViv
I apologize if this has been asked before but I searched through 70 or so threads and couldn't find the answer I was looking for.
Backstory.... 2012 2 door with 4 in pro comp lift on 35s, had some wandering in the past and fixed with caster adjustment but still had a bit of bump steer. Recently Ive been getting a shimmy in the steering wheel going over some bumps. Ive had it before and was able to fix it for the most part with a tire balance and rotation.
Its back again and thought I should look deeper into it and make sure it isn't anything else.. Checked ball joints, no play(I thought odd at 35k miles) tie rod ends no play, draglink no play on the knuckle but small amount of play on the pitman arm side. Not sure but considering that joint is attached to steering it could possibly cause the shimmy ? Seems like a good time to do a drag link flip. Is this something that might help me? My adjustable track bar and drag link seem to be fairly parallel to each other but not perfect.
So if in fact the flip kit will help me, looking at the evo kit it doesn't come with the pitman arm end and I would like to replace it all.. Is it correct that moog part es-3624 is the proper replacement? I still have my stock track bar to put back on with the new bracket if I cant collapse my adjustable enough.
It also said you need minimum 3 in bump stops, I looked inside my front spring and coming from the top down there is a bump stop that is about 7 inches long, but no stop of any kind attached to the bottom perch of the spring.. Is this a correct set up? and why would someone have put in one so long? Ill attach pic of it.
On a second note, as surprised as I am that the stock ball joints aren't shot yet, I would like to install C gussets. Can it be done without the removal of the ball joints? I have read that it can if welded slowly. No point in spending the money on ball joints if they still ok. Do you find it as odd as I do that they are still holding up?
Thanks
Tony
Thanks
Tony
