Evo double D bolt on Long arm kit JK 3.6 install
midnightmods
Hello All,
I am installing a long arm kit from EVO, in a Right Hand Drive 3.6 auto.
Does anyone have picture of how the exhaust is cut and reinstalled in the hoop ? (Drivers side for USA car)
The instructions don't really cover enough detail, I've spent hours on youtube and google looking for install pictures with out much luck.
Requirements- #1 Pictures of how the 3.6 exhaust loop is cut and re-welded,
#2 pictures of the cut front control arm mounts, or the new mounted bolted on/welded on.
Thanks very much :)
I just replied to your PM with my phone number. I am home for the rest of the day and can take any other pics from other angles if you would like. As for the loop, I ran a flex pipe in there for quite a while. I now have a solid pipe in there without the loop for the time being, but my ocd is really kicking in and I want to get it buttoned up with the loop. I am about ready to throw in the towel and pay a pro to do it. Here are a few pics to get you started. What other angles would help you out?
I have a bunch of pics in my build thread how I installed the long arms, but here is a pic of where I cut the exhaust to figure out how I would ultimately weld it back in.
Just realized you are half a world away, so the phone number might not help. Here are pics of all of the mounting points for the front control arms. I took these of the passenger side since the exhaust is a little more out of the way.
First pic you can see the bolts that go through the crossmember.
Second pic is the bolts through the frame. The upper bolt comes out by the body mount you will see in the next pic. The lower bolt is through the factory lower control arm mount
To the right of the body mount is the upper bolt from the evo mount.
And last is the just a pic of the control arms to the front. I guess I should probably get some spray paint on the scratches. I think it's time for 40s...…
Have you tackled the back already?
Does anyone else’s upper front arms wobble like the rest of the arms are tight but the front upper arms I can just move around
I will try getting a video of what I’m talking about tonight and upload a short clip to YouTube and link it if that’s okay
Sounds like the pinch bolt is loose. Get the misalignment joint "centered" and crank the bolts down to 50 ft. lbs.
I got home and I check the pinch bolt and indeed that was my issue and they are torqued down to 50ft thanks again Kevin
See attached,
Kevin can you confirm this is correct. the finger pointing picture is the section I keep and do not cut.
Trainwreck beat me to it. Here is pic of the driver's side before the long arm mount goes in. Clean everything up except the stock lower outer part of the control arm. As I said in the pm, pretty easy to get in there with a Sawzall blade to get the mount to where you can cut it pretty cleanly. After this pic, I went in there with a flap disc to get it all flat without any proud edges.
I have a ton of other pics that I didn't post on here. Let me know if there's anywhere else that you are getting stuck.
P.S. Good on ya for tackling this!
If anyone has any more pictures of the 3.6 exhaust cutting location that would be great :)
I posted a picture of the exhaust cut and laying on the ground... literally all you do is make a parallel cut on the other side of the loop and flip it around. You will have to twist it around a bit to figure out the best position.
