How is the lift height determined for the coilovers or what did you achieve? And are the factory bump stops ok or are the Kings a must?
Donny
Thank you for the info!! These look like a nice setup, a lot more than I was looking to spend but still pretty nice. Initially I thought you had to buy a midarm or longarm system then sub these in....
Donny
Nope, you can totally run the EVO bolt on coil over kit with factory arms (more than long enough) but, you will want to get some adjustable front lower arms just so that you can dial in your caster.
If you buy the EVO coilover system.....what else do you need to make it all work?
Do you run short or long arms on Moby?
What do you set your ride height there to keep your LCG but still run 40's
FuriousDz said:Do you run short or long arms on Moby?
wayoflife said:... and uses coil overs to give you much better performance in terms of ride quality and flex.
At bare minimum, I would recommend that you get their drag link flip kit and a set of adjustable front lower control arms. If you have a 2-door, you would need to get a new drive shaft and a set of adjustable rear upper control arms to set your pinion angle. If you have a 2012-up, you would need to get a front drive shaft as well. If you have a 2007-11 with an auto, you would need to get a new front drive shaft too. With this alone, you can out perform most any other kit out there, long arm or short arm.
I'm sure WOL will jump in but to be clear...Moby does not have the bolt on coilover system but rather EVO's double throw down on the front and evo lever in the rear.
Alright, your gonna have to let me drive Rubicat next time we get together. I'd like feel the difference in ride quality for myself. :thumbs:
The more lift you add, the more the arms become angled, resulting in the suspension having to work harder to be cycled. The longer arms keep your control arm, angles more parallel, which gives a smoother ride and the suspension has to work less when being cycled.
The angle has a big part in how harsh or soft a ride will be.
wayoflife said:This is true but, we originally had run moby with short arms and an EVO lever. Chris is running short arms with his bolt on kit and it's nice.
LOL!! sure, why not :yup:
