If I've removed the center cap of my stock rubicon rim pictured here, should the evo tire bracket fit through it?
I think if you turn the wheel around, it will be more secure/snug. So have the finished side of the wheel facing the rear of the jeep. Or you could run a spacer. The issue is the back spacing of the stock wheel.
The issue is that the center bore of the stock wheels are too small not allowing the EVO adapter plate to pass through.
Just get a hole saw and make it bigger. Lol. didn't realize it wouldn't go through.
... all you gotta do is put the tire on the carrier then slide the adapter over the carrier with the bolt side away from the rim then screw in handle.
You're a lifesaver! I get what you're saying. I'll go try it.
Yeah, I had it ratchet strapped today and it looks ...ok...
So joking aside, how much would taking off that material from the wheel hole affect its strength, I wonder...
I had the same problem. I just ended up buying slabs.
