Dewayne
Hi, I am currently running (on my 07 Wrangler Rubicon Unlimited) 6 inch Synergy coil springs, a full width kingpin Dana 60 front, adjustable control arms, high steer arms and a heim steering kit from RuffStuff, with 41" tires on 18x12 wheels that have a -44 mm offset/4.75" backspace. I know EVO says 3.75" backspace or less required, but with full width axles being wider than stock, I believe that covers the extra inch on the wheel backspacing. I have a couple questions about the EVO kit, and hoping anyone with any ideas can reply, or maybe even Off Road Evolution will see the post. I'm curious if anyone knows if the EVO bolt-on coilover kit lower mounts will work on the Artec JK truss kit that's on my axle. Next question is concerning the low center of gravity (lcog) part of the kit. I really would prefer to keep the height that I'm at, or close to it, which as stated above, I'm using 6 inch front coils from Synergy. If I remember correctly, EVO says their kit is adjustable up to 5" ride height, but if I adjust the 12" coilovers included with the EVO kit to a ride height of 5 inches, am I going to be giving up too much down travel? Does it use up an inch of available droop for every inch of ride height you adjust them to? If I wanted to stay with my current 6 inches ride height, could I use 14" coilovers, so I'm not losing as much of that down travel, and just use limiting straps to limit the droop, if the driveshaft tries to get into the exhaust crossover?
