Hello,
Anyone have any advise on how to quite down my lift kit. I grease it every oil change but that dose not seem to help much.
Are you running a DTD as well or just the long arms? Where are you hearing the noise and what grease are you using?
I'm not running a DTD. Currently I use Lucas X-TRA Heavy Duty Grease.
I've found the best way to get rid of noises in my Jeep is to remove the top and doors. Not only do you not hear shit amymore, the smile on your face replaces that ugly frown when you hear some weird new noise.
Surprised you are hearing noise with your LA kit. I'm running it and have none. Were they greased up really good when first installed? May need to drop them and grease the hell out of them to make sure there aren't any dry spots.
Currie specifically states that you need to be using a moly grease on their Johnny Joints
https://amzn.to/2wLEMzC
I have found moly to work best.
It looks like the #2 has a higher viscosity rating. The numbers at the bottom of the description list #1 and #2Is there much difference between ngl1 and ngl2?
thanks
Thanks I will get this on order pull everything apart and see how it works.
Do you normally have to pull the arms off to grease them? Ive been trying to figure out a way to cycle the suspension in a way to reach the zirks but cant seem to find a way. Retorquing all the arms sounds like a ton of work.
