Have a 1/4 pounder with stinger showing up tomorrow. I have read the write ups on install, but I was curious what size drill but I needed to install the stinger?
Thanks for any help you can give me.
Don't remember the exact size but I bolted it up on the front then used I believe the second biggest size in my standard bit set to drill the holes while the stinger was bolted to the front then pulled it off to re paint the holes drilled out. I just picked the bit that was closest to the hole size.Have a 1/4 pounder with stinger showing up tomorrow. I have read the write ups on install, but I was curious what size drill but I needed to install the stinger?
Awesome. Thanks for the info!
Thanks again for the advice. 3/8 was the correct size and the frame horn trim advice saved me some headache. Now I just need a winch! View attachment 252281
