Error c1405
TraderBear
I am having intermittent issues with c1405 "transfer case range position sensor circuit high".
Jeep goes into limp mode with strange transmission shifting or none at all - once in the middle of intersection.
I have dealership look at it and "reprogram" under warranty due to an update available. Did not work the first time so took it back a few days later.
Jeep has been fine now for over a year and has now come off warranty of course. But has done it again twice.
I have checked wiring ect and everything seems fine. Now looking at replacement.
Suggestions???
Based on the information, a likely solution for an intermittent C1405 "Transfer Case Range Position Sensor Circuit High" code, especially after a software update, is to replace the Transfer Case Range Position Sensor/Switch itself. If that doesn't resolve it, wiring and connectors is the next step.
Suggestions???
Your JK is under warranty?
