dhughes16
A few days ago I had a P06dd code pop up. The engine didn’t seem to be running like anything other than normal but I checked the oil level and it was REALLY low. As I was on the way to Autozone a P0649 (intermittent camshaft sensor) popped up. I checked the connections for the sensors and added 4 quarts to bring it up to full (I do in-fact check the oil regularly so I know that this oil loss was drastic and somewhat rapid). First, I checked for leaks. I crawled under with a flashlight and searched all around the oil pan, transmission, rear main seal , etc...didn’t see anything, least of all something that would’ve drained 4 qts. Next, I checked the radiator/ coolant reservoir and everything looked normal with no oil floating around. When I pulled the transmission dipstick it was full and was dark red (it’s probably 6 months old). Everything seemed fine so I reset the codes to see if they would come back after the oil was topped off. So 2 days later, no codes popped, as I creeped up to 60mph the motor started to intermittently pause. The best way to describe it was that it seemed like the engine was taking a deep breath then going back to work. There was no jolt or clunk it was just like it almost cut off for a split second. No lights or code came up and was only happening above 55 mph. I got off the highway ASAP and checked the fluids. Same results as the first check except oil is a little low and transmission fluid is high.
I’m on vacation in anchorage and have to make the 6 hour drive to Fairbanks in a few days so I don’t really have any of my tools handy. But I have a friends garage to do some minor work
My first question is how fucked is my transmission?
Second question is have I missed anything obvious?
It’s a 2012 JKUR*
It’s a 2012 JKUR*
