Does it tick? I can't tell if mine is ticking or not but I am getting closer and closer to my warranty ending.
What code is it throwing?
I'm going to take it by a friends shop to get the code(s) read before I take it to the dealership. What was odd was another friend on the trip got an engine light on his 2013 rubicon also.
Not 100% sure if this works on the 2012 MY Jeeps and newer, but here is a link on how to check it without using a reader.
http://project-jk.com/jeep-jk-write-ups/jeep-jk-wrangler-diagnostic-trouble-codes-dtc-how-to-check-them-what-they-mean
Thanks Chris I will give it a try!...
...Nice flex on Freeway yesterday, Blake too! The Evo c/o what you expected?
You're welcome :thumb: (It's Bryan BTW)
Thanks! The coilovers are badass! If they are even remotely in someone's budget, I can't imagine getting anything else! :rock:
Sorry Bryan! I've been thinking about getting those but I decided on a PR44 instead. Would like to wheel with you guys sometime to see how they ride.
A PR44!?!? That's going to be a sexy piece of hardware under your jeep! :yup:
We definitely need to plan a trip!
That's what I'd want to know as well. Just because you have a check engine light on doesn't necessarily mean you have a bad cyl head. Could just be an EVAP line is loose.
It works for the 2012s also it threw code P2099.
"Downstream fuel trim system 2 rich"
I'd maybe guess something with an O2 sensor. But I'd take it in for sure.
I read this on another forum from someone who had the same code and this is what his dealer came up with:
They provided me with an extensive protocol: compression test showed cyl 2 was 110 psi while all others were 170-175 psi (leakage test showed 30% leakage). Codes P2099 and "pending fault" for "P0302 = Cylinder #2 misfire detected". It also said that the problem is related to an failed exhaust valve and the valve seat.
