Engine light code p0455
Clifford33
So just got an engine light the other day and ironically after playing in the mud. The code is po455 large leak in evap system. Iv checked the gas cap the evap canister , the evap sensor plug the hoses. Have you guys had this problem? Image1545895232.368750.jpg
Did notice some fluid on the gas tank skid but with the pray on the floor of the Jeep it looks like it was from the drive shaft, pinion seal and just flinging fluid all over. ?? Time for new drive shafts as well.
There's several posts here on how to track down and fix an evap leak. For me, it was the vacuum pump and seal on the canister. For others, it was the plastic line on top of the tank. I'm lazy, so below is a Google search that brings up a lot of reference.
And, yes, a smoke test is quick, but if it's a big enough crack, you'll see it.
https://www.google.com/search?q=sit...oid-sprint-us&sourceid=chrome-mobile&ie=UTF-8
Ok cool thanks man!
Just had that issue a couple months ago. Replaced the o-ring, 3, on the evap canister, well the canister too since I was doing that anyway, and fixed.
Engine light code p0430
Got my jku in June with 133k love it so for put valve cover gaskets on replaced pvc valve as well Jan 1 get this p0430 says it’s bank 2
In converter where to start troubleshooting ? From what I’ve read could be a number of things. Anyway what has anybody done to fix?
