Also, I don't know if this will help someone that may come across this topic wondering the same damn thing but who knows:
The manual states for a 2021 Jeep (at least for 2.0 engine) and it's engine coolant/intercooler fluids [which use the same fluid]: "We recommend you use Mopar Antifreeze/Coolant 10 Year/150,000 Mile (240,000 km) Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of FCA Material Standard MS.90032."
Organic Additive Technology = Organic Acid Technology; long life coolants (llc).
Don't interchange/confuse HOAT, IAT, and OAT. Your engine will fail if you mix.
While the coolant should be purple, the production liquid may be different. Also, light, temperature, and age of coolant may change the color. So never go by color alone.
I don't know why this hasn't been fixed yet in the manuals. You won't find MS.90032. You'll need to use MS.12106. MS.12106 is the 50/50 premixed and exactly what the dealership will use to top off fluids.
The product you need is: 68163849AB. It's pre-diluted, no need to add water. Older Jeeps may take something different, I think pre-13 models are a different ballgame.
Apparently, all this stuff was done on purpose to get you to go to the dealership for service. The different colors, numbers in manuals not matching numbers on Mopar parts, etc.
