Showroom
Anyone had their cel light come on and throw this code? P06DE
Has something to do with engine oil circuit open. The only thing I could find was something about re flashing the PCM.
With that being said I was going to take it in to the dealer but when I used the restore feature in the procal to remove its programing it also cleared the engine code. Restore and clear DTC codes should be separate features on the procal so I'm not sure why it did that. From what posts I've read I should remove the procal programing to avoid issues with it not working after it comes back from the dealer. So now I'm at a loss about what I should do. Wait to see if it throws that code again and not use procal or what. Any thoughts?
I'm using procal for gears and tires 35, 4.56
