Azblackdog13
Ok guys, its me again looking for advice. Can anybody help me locate the engine block coolant drain plugs on the 3.6. Also the best way to super flush cooling system. Again thanks
Sounds like he may have already mixed the two coolant.Before you wreck your engine and your cooling system i would check to see if that is compatible with the antifreeze that is in the JK, and depending on your year their are two types, also i don't recommend flushing the system as those additives and stuff that are in engine flushes can cause damage to other components in the system, if your going to flush your system i would use good ol tap water only.
