Couple questions. The front control arms says in the instructions to install with the clamp towards the axle with the grease zerk up. The front grease zerk is shrouded by the bracket on the axle. Is that right?
The instructions refer to replacing both the front and rear brake lines too. I'm guessing the supplied ones are for the rear? What are you doing to the front?
Comes with one set of sway bar links which look like they are for the rear also. What do you do with the front?
