I used a 3 jaw puller to extract the rotor on the driver side. The hardware on the other side seems ok because I was gentle after learning my lesson on the broken side. From what I have seen it looks like the rear spring is going to be difficult plus everything just wants to fall apart and I feel like I need to be an octopus. Really I'm probably just putting things back together in the wrong order. Do you put the hold pins in first? Mount one of the heavy springs, etc. I heard the setup sucks and is prone to failure but removing it is not a option because it's a 6 speed. Thanks for the reply
Thanks a bunch everyone. I've pulled the hub off the front before when I did my ball joints so the shaft removal should be straight forward. The bearing is pressed on the shaft so it might be a bit difficult to get the axle to budge. From what I have heard there is nothing you have to do to get the axle to come out in the differential housing like you had on TJ's correct??
You do not have to pull the axels to replace those brake shoes. If you got the old ones off you can certainly get the new ones back on. Get a helping hand if needed to hold parts steady.
Good luck. I tried and tried and that's why I ended up taking the shaft out and then it was very easy to work on. Work smarter, not harder. At least that's my motto.
Thank you both for the info. Was the axle hard to get back in and did you have any leaks after. Any new seals necessary.
I HATE the Chilton book that I have currently. The black and white pics are generic and useless. I'd like to have the Jk mopar shop manual but can't get a hold of pdf
