Electronic Disconnect Broken Bar
Micjeff89
58AE9BB0-9FC9-46BB-B50F-1A19E1B6FE7F.jpgwas hoping to use the evo manual disconnect to fix the electronic sway bar issues, however it appears i may have bigger issues now.. has anyone had the bar break or loose like this before ? also if anyone has removed the bar from the disconnect housing how did you get it out ? thanks
I tried to upload video but it didn’t work. In The picture you can see how there is a gap between the bar and housing. The entire housing completely moves and is loose. Seems like potentially bushing failed?!
View attachment 300876was hoping to use the evo manual disconnect to fix the electronic sway bar issues, however it appears i may have bigger issues now.. has anyone had the bar break or loose like this before ? also if anyone has removed the bar from the disconnect housing how did you get it out ? thanks
Do you have a picture that is any worse? It’s more fun when we don’t have a clue what we are looking at.
This really isn’t hard to understand. It’s where the sway bar goes into the electronic disconnect. Seems like the bushing have broke
wheel in mud often? looks there's water mixed in the grease causing the whole thing to rust together
