OverlanderJK
Resident Smartass
Dynatrac Dynaloc Hub Rebuild or Installation
I am not a professional and have never taken these apart before. I searched and could not find anything online showing how this was done other than a couple bad videos. I reached out to a Dynatrac who was unable to provide directions to me so I was doing this blind. Overall it is fairly easy as long as you take your time. Install time while doing this write up and pictures was about 45 minutes. Should take 15-20 minutes if you know what you are doing.
Tools needed:
- Rubber Mallet
- Flat Head Screwdriver
- 5mm Allen Wrench
- 3/16” Allen Wrench
- Picks
- Dykes
- 2 5/8” Spindle Socket
- Torque Wrench
- Brake Cleaner
- Automotive Grease
You may need a breaker bar and will need tools to remove tires and brake caliper. Not included in the above.
Bare spindle with new ABS wire installed using a 5mm Allen wrench.
This photo shows the seal and the first bearing already installed in the hub as I did not need to remove them. Clean the tone rings if required and back of the hub.
Insert second bearing. You will need to hold the hub up in place until the second bearing is installed. The hub will want to fall until that is inserted.
Install first spindle nut and tighten to 50 ft lbs using spindle socket and torque wrench.
Installed spindle nut “lock washer”, second spindle nut and torque to 70 ft lbs. after torque is applied fold over ear of “lock washer.”
Insert collar and plate. Make sure to push both pieces all the way in. It may be necessary to spin the hub while pushing to get these fully seated. The plate needs to be installed with the dimple facing in.
Next install spring into locking hub piece. The larger of the two. (If anyone knows the name I will add that)
Slide brass ring onto shaft of outer hub lock with the bevel facing in toward the axle and away from the teeth. Slide over axle shaft and into hub.
Install locking snap ring. You need to ensure the entire hub assembly and all pieces are pushed all the way in to fit snap ring into the groove on the shaft. If the pieces are not pushed all the way in you will not get the snap ring to seat.
Install outer hub locking plate and spacer. Flat side of spacer facing in and flat side of plate facing out. This is what will catch the hub and lock it as it turns.
Install large snap ring into groove in the hub assembly
Install dynaloc cover with three Allen bolts
Tools needed:
- Rubber Mallet
- 5mm Allen Wrench
- Picks
- Dykes
- Torque Wrench
- Brake Cleaner
- Automotive Grease
