J jimmy666 New member May 1, 2023 #1 In the last 5 months my 2012 Overland has just died at a red light 3 times. It fires right back up. Any ideas? thanks
JT@623 Hooked May 2, 2023 #2 jimmy666 said: In the last 5 months my 2012 Overland has just died at a red light 3 times. It fires right back up. Any ideas? thanks Click to expand... It’s tired from all the overlanding . could be crank trigger, fuel pump ,the list gos on , check all your grounds first a loose ground can cause multiple problems.
WJCO Meme King May 2, 2023 #3 jimmy666 said: In the last 5 months my 2012 Overland has just died at a red light 3 times. It fires right back up. Any ideas? thanks Click to expand... What engine size? How many miles? How are you with overall maintenance? Does it sit a lot or is it driven regularly?
JeepFan Hooked May 2, 2023 #4 If you're not getting a CEL or finding any trouble codes in the PCM, I'd start with a crank position sensor and see if it solves the problem.
DirtHeadDavis Hooked May 2, 2023 #5 My buddy had this problem on both his 2012 Grand Cherokee and 2018 Cherokee KL. Both instances were bad grounds on the battery.
