jk12blk
Dynatrac is making me the following custom build (great fit for my use case).
I wanted a stronger axle assembly compared to my factory dana 44, but I did not want to deal with swapping out my ATX Slab 5x5 wheels for full 60.
Prorock 44 was an obvious choice or the Currie 60/44 hybrid.
If Currie can do a 60/44 hybrid, why not Dynatrac?
So I asked Dynatrac and they came up with the following build below (first ever)....
Dynatrac Pro Rock 60/44 Hybrid Partial Front Axle Assembly w/ARB Air Locker - 07+ Jeep JK
- *Custom Machined Dynatrac Pro Rock 60 High Ground Clearance (Reverse Cut) Heavy Duty Nodular Iron Housing
- Heavy Duty 3.125" Diameter, 1/2" Thick Wall DOM Housing Tube Assemblies, Installed
- Dynatrac Pro Rock 60 Heavy Duty Nodular Iron Powder Coated Differential Cover, Installed
- Stock JK Axle Width - 65.5"
Coupled with a 35 spline RCV inner/32 outer, and 35 spline ARB, should be good to go with 60 gears.
One potential "gotcha" is the tie rod clearance lock to lock.
Fortunately, a local fab shop ensured me this will not be a problem.
Ready to pull the trigger Monday.
My JK weights 6400 lbs and will never exceed 37" tires.
Rear will be Dynatrac semi float Prorock 60 - 35 spline axles and ARB.
ready to get this party started!
