I installed halo DRL’s recently. I wired the switch to the fuse box as recommended using a fuse tap. Everything works as it should except for one issue. The lights on the air con knobs stay very dimly lit even when the Jeep is off. It’s just the small green light on each knob and it’s a very dim glow but they are definitely lit and stay lit all the time when the Jeep is off. Nothing else is lit at all. Just the three knobs. I’ve used two different fuse locations just in case and it’s still happening. Any thoughts as to what’s causing this?
