Mountainjk10
Going to be ordering new driveshafts soon. Should I go with greasable or solid u-joints?
Thanks for the replies. One question I have is, are the solids that much stronger than the greasable?
Solid u-joints are just that, solid. There are no zerks, flat or standard. Now the double Cardan is something different. That may or may not have a zerk. My 1310 JE Reel front did not have one while my rear did. It started chirping at me around 25k. When I had it rebuilt I had it rebuilt with solid u-joints. Also you can use a needle fitting on a standard zerk just take a little finesse to get the grease to go in.
I think it depends how much torque you’re laying into it. A stock JK should be fine with greasable ujoints depending how you hook up the tires. I’d rather bust a u-joint than other driveline components. Unless I’m building up the whole driveline from the engine back I’d stick with the ease of maintenance.
