What's involved with moving the evap skid? I haven't looked at it yet.
You can use a skid and/or relocate it. Lots of companies make parts to do either. I have heard of some skids needing to be trimmed if you decide to use the evo spec dynomax exhaust. Rock hard makes a easy relocation kit. I've also seen DIY threads.
You just need to drill new mounting holes in the skid plate and shift it over. Super easy to do and you don't even need to take the skid off.
You shouldn't. I've been running a stock rear shaft on my '12 for over 20K miles.
Make sure you move your evap skid over a couple of inches before flexing the keep out. Otherwise you will tear your DS boot. Ask me how I know.
If its already torn a bit should I still move the skid over?
Thanks
Russ
Thanks
Russ
Glad I read this!!! Getting my '12 back today and didn't even know this. Here is on my list to do on my '12 JKUR. Sorry to hijack but anything else missing?
Transmission Skid
Oil Pan Skid
Front Drive Shaft Replacement
Front/Rear Diff Cover
Move Evap Skid
Other items?
Thanks!
Transmission Skid
Oil Pan Skid
Move Evap Skid
Other items?
Thanks!
Edit: Why am I always one second behind Eddie? LOL!
Maybe because I'm running at set of 40's :idontknow: :crazyeyes:
Yeah, I would and, I would look into saving up for a replacement shaft in the future. With the boot compromised, it's just a matter of time before things start to seize up and do more damage.
Is it worth replacing the stock boot or just a waste of time?
Thx again.
Unless things have changed, you can't replace just the boot. The dealer will want ~$800 for a factory shaft.
