All right at the top of Adams website........
With the Impact gun tighten down the pinion nut until the socket comes to a stop.
NOTE: DO NOT KEEP TIGHTENING THE PINION NUT AFTER THE SOCKET HAS STOP. If you keep tightening the nut you will over crush the crush sleeve and the pinion bearings will burn up. If you are unsure of this step please give us a call at 702-568-5680 and we would be glad to answer any questions you have, or consult a professional mechanic.
Check to make sure that there is no play in or out, or up and down on the pinion yoke. If there is some play then the yoke has not been tightened down to the crush sleeve yet. Continue tightening until there is no movement in the yoke in or out, or up and down.
