What springs did you install? You might benefit from a flip. That would take care of the problem.
It's going to keep happening. Does the upper end of draglink have any pinch bolt or way to lock it from rotating as far? If it's just a noise, you could put some pipe foam on it but it will look like shit. Probably won't hurt anything to leave it but cosmetic marks will appear over time.
This.Loosen the jam nut on the pitman arm side. Rotate the TRE on the pitman arm back, rotate the drag link forward (up). Tighten the jam nut.
