I thought AEV had a set that was DOT compliant, but they may be discontinued.
This DOT compliance issue surfaces periodically, seemingly by a poster who assumes it has significance. But does it really? I have never seen any actual or anecdotal evidence of it. FWIW, I’ve been running Chamber Pro IIs for years with no hassle from the po pos.
So this could go a few ways.
#1 Hutchinson says DOT compliant which means not officially DOT approved.
Is there any DOT approved wheels?
#2 + #3 disregards DOT
#2
What wheels are people most comfortable running or has the best track record on the road?
#3
What rims have more of a problem holding air for extended periods?
#2
#3
What is it that has you concerned? Unless the police are pulling people over all of a sudden and checking the wheels for a DOT stamp on them, there really isn't an issue running beadlocks on the street - many many people do so. These wheels are completely safe BUT you do need to check them periodically, like checking the ring bolts every oil change. Mine haven't needed any tightening in the 4 years I've run them on the street. Consider the beating these wheels take running the Baja or KOH races and I would be willing to bet that there's not a situation on the street that punishes wheels anywhere near what those guys do.
Never stated I was worried about being pulled over.
More worried about holding air pressure over long hauls which DOT approved might have an advantage.
Mine are DOT approved. B.A.D. wheels.
Those look like a chore to mount.
How did they go together for you?
There is no advantage. Haven't added air to mine ever.
