Hello everyone, a little preface on to my problem that I've had since day one. I have a 2013 JKUR10A and when I would remove my hard top and there was no longer anything pressing against the top of the driver side rear door, every time I went over a bump it would rattle and drive me CRAZY. I know there are many threads dedicated to the infamous door rattle and I am aware that there is a TSB out there for it which call for the technician to just simply "apply grease to the striker plate and cycle the door" which I assure you I had no luck for me. I know others have had varying degrees of luck with the electrical tape fix as well but it is a temporary fix. I just wanted to post up my seemingly more long term fix that I think looks good as well. All you need is a tube of plasti-dip (not the aerosol)
here are the steps:
here are the steps:
- Remove latch plate and backing plate with Torx bit
- Clean latching bar with soap and water and dry it
- Dip just the hoop into the tube of plasti-dip (you may need to hold the tube at an angle to get adequate coverage) and be sure not to coat the flat plate
- Let dry for at least 4 hours
- Reinstall backing plate and latch plate
