BlueRubicon
For those that do, I am sharing some advice. I have been wheeling my 18 JLUR since Feb of 19. For the most part, the the exhaust has been mostly unscathed. I saw a dent in the muffler, cannot say when exactly; but shaking the tailpipe I could tell muffler was secured. Well, at sometime recently, the driver side muffler hanger broke. Yesterday, after putting new RCV's in, I went up to where we wheel to just make sure all is well before I go to Moab in two weeks. I did not do anything extreme. In about 45min I started smelling coolant. I looked under engine area and didn't see anything. Temperature guage was normal.
I get home, pressure wash it off, swap out the 37's for the stock 33's because I plan to trailer the 37's. I digress...I notice under driver side door fluid. Looks like red fluid. The coolant lines for the 48v battery run along the frame underneath the cables chase, very close to the exhaust. I look at these often, to make sure exhaust is not getting any closer or touching them.
Well...metal tubes run from the engine compartment towards the back. Right by the crossmember, there is a 6" section of rubber hose, that couples the lines to the metal ones, that then continue on to the 48v battery compartment. Red coolant is dripping from hose clamps. But... only because this is the low point. About 8" closer to engine compartment, there are offsets in the metal tubes. The exhaust pipe is right up against it. The stem on the pipe, which goes into the bushing is pulled out most of the way. Looks a little bent. With a prybar, I move the exhaust off the coolant lines, and I can see where it burnt through. Now Im fucked. Dealer will tell me it isnt covered because obviously I off road it, and bent the exhaust. My dealer sucks anyway so Im not even going to bother with them.
I will figure something out...however moral of the story is...Definitely get the Rustys muffler skid!!! Also I strongly recommend welding a piece of steel on the frame to saddle the coolant lines as to prevent exhaust from ever touching them!!! FCA definitley didn't do the R&D. These lines are probably on nobody's shelves yet and I would venture to say weeks out. Dealer will not modify shit, only replace. Save yourselves the grief and protect the exhaust as best you can and at the least, the coolant lines.
To those who say..."this is why I didn't buy the 2.0L"...well you were fucking right!!!
