Diver_matt
Any tips for rebuilding a krawler joint? The side nuts are ridiculously tight, set screw removed. The joint itself is crazy tight on the control arms, too (on some). My RK tie rod has a place to use a wrench to hold it while removing the TRE but the control arms don't. Short of taking it to a welder in stuck. Any tips for getting them off a control arm AND getting the joint apart? They were sprayed with liquid wrench a couple times last couple days. Thanks, in advance.
