Honestly, you can't really go wrong with whatever gear oil you choose to use. If you have a limited slip differential, you will want to add friction modifier or a synthetic gear oil as it will have it in it. Otherwise, if you have ARB lockers, I would recommend that you do NOT use synthetic oil as it will damage the o-rings and cause air leaks.
