Difference between aluminium evo bumper and quarter pounder?
Christarp
Hey guys, I just found a pretty nice deal on a warn zeon 10S and I remembered it doesn't fit in the evo quarter pounder, but it does fit in the aluminium version evo makes, which makes me wonder why it doesn't fit in the regular quarter pounder.
Anyone know what would be required to make it fit in the steel quarter pounder?
The regular steel one has a off set winch set up with a single set of holes in the bottom. From what I've seen, the aluminum has two sets for which ever you decide. Not sure how the fairlead mount hole is situated.
Aluminum is in the middle.
I think the zeon requires fairlead in the middle.
Just looked at smoking v8 build, I know he has the aluminum bumper, and the hole is centered, the steel is off set. Sorry for the confusion. I just wasn't sure how it came.
Hmmm, so it looks like the only way to fit it would be extending the fairlead hole, and then buying another plate and making it a normal size and bolting it to the front of the bumper to essentially move the fairlead hole and still be able to mount the fairlead itself.. And then drilling new winch mount holes.
Hmmm, going with aluminium would negate some of the savings of the deal I have on the winch... and I assume it would prevent you from running other "normal" winches that aren't centered?
In addition to the OP, I have a question reg. The aluminum bumper by Evo Mfg - is it 1/4 inch thick just like the steel version?
One minor difference is that the aluminum 1/4 pounder does not come powdercoated black it comes raw. I went aluminum because of the warn zeon and was told that the steel version was NOT an option.
Does anyone know the weight of the aluminium version?
(I now the steel version is about 90 lbs with D-ring mounts.)
It's super light. I think somewhere around 25lbs?
I believe the newer 1/4 pounders in steel allow for both centered and off centered mounting.
:beer:
They have it so both aluminum and steel have the two sets of holes for the winch. Specifically the zeon.
Asked the same question. This is what Drew emailed me
The "new" EVO MFG PRO Series front bumper with hoop weighs 75lbs and is steel. The ALUMINUM 1/4 Pounder weighs 30 lbs, the STEEL 1/4 Pounder weighs 90lbs and the Stinger for the 1/4 Pounder weighs 46 lbs.
BOTH the STEEL 1/4 Pounder and the ALUMINUM 1/4 Pounder will accept an OFFSET or a CENTER mounted winch. The original design of the 1/4 Pounder was OFFSET only, but that has been updated.
The BIGGEST difference between any materials such as steel vs aluminum is Heat Treatment.
Having worked on Aircraft for over 25+ years, it comes down to your knowledge of basic metallurgy.
10 year bump. How are we feeling about the steel vs aluminum Quarter Pounder from a longevity perspective?
I have the steel on my JK and the wife has the aluminum on her Gladiator. The aluminum version is slightly less resistant to rock rash than steel and paint seems to be less adhesive to the aluminum. Neither of these is an issue that a rattle can of paint cannot fix. I went with aluminum on the JT because it’s a diesel and I wanted to cut down on front weight. The only change I would make is to look at having the aluminum bumper anodized if it’s not prohibitively expensive.
