Diff covers
Gecko12
My rear differential has been dripping occasionally for awhile now. Knowing I need to replace the gasket I might as well throw a new diff cover on at the same time.
I have a 2012 Jeep JK 2 door with RK 2.5 (netted 3.5+) and a stock track bar with RK trackbar relocation bracket.
I'm looking for one that clears the stock trackball without modification.
Amy ideas??
Also what are everyone's opinion about using lube lockers vs RTV?
Amy ideas??
Front or rear diff cover?
With a raised track bar bracket most covers should fit I believe.
Go with RTV. I have a lube locker on my front and have to torque the bolts about once a week.
I have always used "the right stuff" by permetax. Have never had a leak on any of the diffs I used it on.
Rear diff cover.
I have a RK front trackbar so clearance won't be an issue in the front.
The rear is fixable by just grinding down the lip of the cover a bit so it's less than the housing. This will help keeping it from leaking in the future.
As far as sealer goes get the "Right stuff" by permatex
This ^^^
And this ^^^
The Right Stuff is what I would recommend using as well.
Also, you can always grind the edge of your diff cover so that it sits above the base of your diff housing. That will prevent it getting caught in the future and cause a leak.
This ^^^
And this ^^^
This is what I did. It's really crazy that the factory didn't clearance the bottom of this cover. All sides with the exception of he bottom lip of the rear cover are clearanced by about 1/16 to 1/8. Why they didn't extend that all the way around is weird.
This ^^^
And this ^^^
The right stuff comes in a grey and black, which one do you use Eddie?
