I've been appreciating all the great knowledge I've gained from the threads and my discussions in this forum. If I can lean on that knowledge base again, I'd sure appreciate it. Long story short, as some of you may know, the previous owner of my 2012 JKU installed a 3.25" Rough Country lift kit. I've addressed some of the issues with adjustable track bars, geometry correction brackets and adjustable control arms to dial things in, as well as improve front caster. For aesthetic and functional reasons, I'd like to reduce the height of the lift.
RC's kit shows that there are 0.75" coil spring spacers included that go between their "lifted springs" and the OEM coil spring isolators. I contacted RC directly to confirm whether I can simply remove their spacer and reuse their springs with the OEM isolators, and they said yes, although I'd want to get a realignment afterward. I contacted some of the manufacturers of the other components (i.e. Rancho regarding which slot to use on their geo brackets), and it seems like this should be fairly straightforward. The question I'm left with, is what is the most efficient way to do this? I had good luck using spring compressors when I installed the MC coil spring retainers.
I know that the other way to do this would be to support the Jeep's frame with jackstands, disconnect the shocks, swaybar end links, and the trackbar and get enough droop to separate the springs. Since I only need to make enough space to pull the coil spring spacers and OEM isolators out, is it possible to support the frame on each corner in turn, compress the spring enough to pull that spacer out and then re-seat it? Either way, I'll probably need to bring the Jeep into a shop to get it realigned and possibly have the rear control arms adjusted (unless the figures @wayoflife suggested in a past thread would be invalid after this change) and things of that nature.
